Heater blows cold
Old Sep 21, 2013 | 01:13 AM
peter fisher's Avatar
peter fisher is on a distinguished road
Default Heater blows cold
hiya all wonder if you can help i have a 1999 cevy Blazer the heater blows cold on hot setting, have checked the fuse in drivers area ok any help would be appriciated.
Old Sep 21, 2013 | 10:58 AM
rriddle3's Avatar
*Moved to '2nd Gen Tech'*
Old Sep 21, 2013 | 01:47 PM
sky_blazer's Avatar
sky_blazer is on a distinguished road
your heater hoses may be clogged
Old Sep 21, 2013 | 03:21 PM
toyhauler1283's Avatar
toyhauler1283 is on a distinguished road
It might also be possible your heater door is stuck on the cold side not switching to warm side
Old Sep 23, 2013 | 11:12 AM
jimspahr@msn.com's Avatar
It may be the heater hoses or the heater core itself is clogged. With the engine off and the heater temp on high/all the way to RED/ remove the two small heater hoses at the water pump. With low pressure water hose, flush first one way, the the other to flush the clogged lines out. If you use high pressure water, you could damage the htr core. The GM long life coolant Dex Cool often causes problems and sludges up when not changed often or mixed with the 'green' coolant.
sprbld417
Aug 29, 2010 08:43 PM
rdhack
Feb 9, 2008 10:32 PM
as2higpark
Oct 18, 2007 12:18 PM
havrelm1
Jul 26, 2007 01:13 PM
Inferno
Oct 22, 2006 08:56 PM
