heater control vacumn
Old Dec 31, 2009 | 08:00 AM
blkblazer's Avatar
blkblazer is an unknown quantity at this point
Default heater control vacumn
My heater quit switching between def. floor etc. It stays on the front dash outlets. I can hear a hissing from behind the dash.
Would my heater control unit be leaking or something else.
1999 S10 Blazer 2 door LS auto 4x4.
Old Dec 31, 2009 | 09:04 AM
It definitely sounds like you have a vacuum leak behind the dash. Time to get under there and have a look.
Old Dec 31, 2009 | 10:07 AM
blkblazer's Avatar
Default heater vacumn
I just got it apart it is right at the switch where the vaumn lines connect. Guess I need new heater control thing.
Thanks
Old Dec 31, 2009 | 10:10 AM
So the leak is internal to the HVAC control head? If so, then you likely will need to find a replacement, either new or used.
Old Dec 31, 2009 | 10:30 AM
blkblazer's Avatar
I guess it is the control head. I took off the vacumn hose connector it looks ok.
$77.00 Rock auto. Local parts store no can get go to dealer they say.
Old Dec 31, 2009 | 10:31 AM
The manual heater control is fairly common. I would check with some junkyards in your area before dropping that kind of money on the part.
Old Jan 8, 2010 | 05:27 PM
blkblazer's Avatar
Anybody that would like to know new heater control assembly fixed the problem. No more hiss at the switch.
Old Jan 8, 2010 | 06:18 PM
Glad you got it fixed and thanks for the followup!
blkblazer
Dec 4, 2010 03:01 AM
doubleuap
Dec 13, 2009 06:08 PM
kota04sxt
Dec 10, 2009 09:34 PM
1badblaze
Sep 29, 2008 05:50 PM
Derbytown
Aug 23, 2005 12:00 PM
