Heater core Frusterating
Old 08-23-2009, 08:34 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
Pic was very helpful. That connector goes to the top right of your box. "Electric Actuator (temperature)" is the name of what it plugs into. Open your glovebox, there's a J-hook top left. Push up on it and open your glove box *all* the way. (here's where it gets hard) Behind the silver actuator arm you'll see a small black box on top of your heater box. That connector plugs down into it, to the right of the small screw. Connector faces front to rear - latch going to the right. Long needle nose pliers would very helpful. (looked at mine, HOO BOY!)
Old 08-23-2009, 08:51 PM
mav06's Avatar
mav06 is on a distinguished road
Sweet got that fixed would have never found that connection lol. So now my heat works but now were the air goes that control dosen't work were would i start on that?
Matt
Old 08-23-2009, 09:26 PM
RonJon's Avatar
Assuming your blower motor works, you can hear the speeds change. When you move the range control do you hear anything happen, any doors moving? I went home and my manuals are where I work so I'm in guess mode now...... I recall that even in the off position vacuum is directed to two of the actuators. Any chance you left a line off? Did you have to remove any lines to change the core? To start from the beginning I guess I'd pull the dash trim and pull out the heater controls. Pull the connector off of the mode switch and start the truck. Check for vacuum at the black line. (just put your finger over it or you'll hear a hiss). If you don't have it doors won't move. (broken line or pinched shut) Other than that I'd say you have a line off an actuator.. Which one? <shrugs> If you happen to have a vacuum pump I'd say try pulling a vacuum on the other colored lines and see which one is open if the black is working. I've pinched wires putting things together, I figure maybe that vacuum source might've gotten between the box & firewall?
Old 08-23-2009, 09:37 PM
mav06's Avatar
Ok thanks so much, the blower motor works and i can hear the speeds change. I do not however hear anything with the doors opening or anything so i would have to assume maybe it would be the sorce of the vacume because non of them work? What do you think? sure do apprecate your help and your time.
Matt
Old 08-23-2009, 10:27 PM
mav06's Avatar
well i figured out my problem i had read some other threads and they were talking about some vacuum lines in the driver side engine compartment up by the fuse relays and well i had one that had rotted away. so watch those hoses lol. Thanks so much for your help ronjon i really appreciate it.
Matt
tdannar
16
08-03-2009 08:25 PM
ShadowHawk
23
11-12-2008 01:50 PM
ericmiller5000
12-13-2005 01:26 PM
Blue Vette
11-14-2005 02:31 AM
aspenpup
07-03-2005 06:56 AM
Quick Reply: Heater core Frusterating
