heater problems
Old Dec 13, 2010 | 07:20 AM
deltas69's Avatar
deltas69 is an unknown quantity at this point
Default heater problems
blower fan only works on high..replaced the control module in the dash as well as the resistor under the hood..i can live with the fan on high..but here's the problem.. it will not work when the temp falls below.30 degrees or so..right now 15 degrees and no blower fan..the fan works fine as long as the temp stays above 30 degrees or so..any idea's ?? thanks..pj
Old Dec 13, 2010 | 07:57 AM
stlwaco's Avatar
stlwaco is on a distinguished road
The resistor went out originally. Sometimes when this happens the wiring can burn. You will have to look at that. If it doesn't look burnt out near the resistor, then your next step would be to test power going into the resistor for each speed. If all is good there check the resistor outputs.
Maulsmasher
14
Dec 16, 2009 09:01 PM
upblazer95
Apr 4, 2009 08:27 PM
MarcoMan
Dec 20, 2005 11:35 AM
Silverfox
Mar 15, 2005 02:51 PM
dawne fischer
Dec 21, 2004 12:16 AM
