Heater problems
Old Jan 25, 2012 | 03:26 PM
potnick's Avatar
potnick is on a distinguished road
Default Heater problems
Blower won't work at all. Unplugged plug to blower and applied direct power. Blower runs strong. Removed control cluster from dash and replaced with another cluster obtained from junk yard. Ran normal for about 2 weeks and quit. Replaced resistor, still nothing. Took it in for an unrelated repair at repair shop and had them look at it. They said it could be blower motor regulator and it was 490.00 for part alone. Having trouble finding anything about this part, as to location and removal and replace. Not in Chilton or Haynes. I have a problem spending this much on part if problem doesn't resolve the problem . I need any info that will help resolve this situation. What is blower motor regulator and where is it located at???? If I find out where it is will replace with one from wrecking yard. Is this the problem???. Also replaced the relay 2 yrs ago.Replaced blower motor at that time also.
Old Jan 25, 2012 | 05:16 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
hmm i think they might have meant the blower motor resister its about 20 bucks at autozone
Old Jan 25, 2012 | 05:43 PM
step66's Avatar
Hey potnick! This really sounds/seems like the resistor! Try a NEW one and I think you'll lick the problem!
Old Jan 26, 2012 | 03:46 PM
potnick's Avatar
As already stated in post I have already replaced the resistor. It was regulator I was told to replace. Looked it up and it is different than resistor. It looks like a black plastic box with a number of wires coming from it.
Old Jan 26, 2012 | 04:37 PM
pettyfog's Avatar
Note the dash ACC moule sends a signal down ppl white to the speed control.
You can put a DVM on that set to DC volts and see volts variation according to changing the ****, then the dash control works.
That 'resistor' on brn wire between the actual speed control and blower motor, I cant explain.
Old Jan 29, 2012 | 05:29 PM
smitty1977's Avatar
smitty1977 is on a distinguished road
do all blazers take awhile to heat up?
Old Jan 30, 2012 | 04:09 PM
bmodzelewski's Avatar
bmodzelewski is on a distinguished road
mine heats up in no time... even during the winter
Maulsmasher
14
Dec 16, 2009 09:01 PM
upblazer95
Apr 4, 2009 08:27 PM
MarcoMan
Dec 20, 2005 11:35 AM
Silverfox
Mar 15, 2005 02:51 PM
dawne fischer
Dec 21, 2004 12:16 AM
