Heater problems...
Old Oct 19, 2005 | 10:19 PM
chessielex's Avatar
chessielex is an unknown quantity at this point
Default RE: Heater problems...
Thank you all for your input on the heater problems. I went looking for the answer to my heater problems on my 2001 blazer and found this site and my husband performed the task of blowing out the heater hoses and it worked. Save us a lot of money. Thank you once again.
Old Oct 20, 2005 | 06:35 PM
stmanser's Avatar
stmanser is an unknown quantity at this point
the only prob with getting a flush is it could break loose the deposits that have blocked off a hole or a small leak... i got a flush done on a grand am once and it blew the heater core out...
just fyi...
be careful with flushing a neglected system..
Old Oct 29, 2005 | 02:44 PM
gatopescado's Avatar
gatopescado is an unknown quantity at this point
I just joined the forum. I'm having the same problem, no hot air blowing. I'm glad I joined as I might can fix this myself. Thanks to all who replied earlier.
Old Nov 20, 2005 | 11:44 PM
greenblazer72's Avatar
greenblazer72 is an unknown quantity at this point
I have had that problem with my 97 for me it was a combo, my water pump was going out not putting out enough flow and my heater core was plugged, but do check the upper and lower radiator hoses for cold and hot , lower hose cooler.
Old Dec 16, 2009 | 09:01 PM
Johnny21usaf's Avatar
Johnny21usaf is an unknown quantity at this point
Default my heater wont get hot...
i changed the heater core, both hoses in and out of the core are equally hot not warm. I changed the thermostat to a 195. it will blow warm air but it takes forever to get even semi warm inside. What else could there be? Blower motor? resistor? Fuse?
upblazer95
Apr 4, 2009 08:27 PM
LoLoS10Blazer87
13
Feb 24, 2006 06:57 PM
MarcoMan
Dec 20, 2005 11:35 AM
Silverfox
Mar 15, 2005 02:51 PM
dawne fischer
Dec 21, 2004 12:16 AM
