Heater Problems- Read every post...
Old Jan 28, 2009 | 04:33 PM
corvettejm's Avatar
corvettejm is an unknown quantity at this point
Default Heater Problems- Read every post...
Ok I got a 2001 Blazer Lt and am having heating issues. Here is the deal: when I am at normal temperature range (right below 210) the heater blows cold air at idle to around 2000rpm. However, when i am at 2000rpm (roughly) and above it will blow hot air.
Here is what I've done:
I checked the inlet hose to the heater core and it was hot, checked the outlet hose it was warm. SO... I did a backflush to the heater core to flush anything out, but I didn't see any junk come out. Just water mixed with anti-freeze and then just clear water. The water came out the same pressure as I put in. So i blew out the remaining water... filled up with anti-freeze again. Ran the engine again.. checked levels.. good. I am not sure what the cause of the problem may be beeing as I get hot air at over 2000rpm...
Any suggestions? Anything that I am overlooking?
Old Jan 28, 2009 | 04:35 PM
corvettejm's Avatar
Default RE: Heater Problems- Read every post...
Oh, also it is manual temperature control..
Old Jan 29, 2009 | 01:47 PM
I would say air in the system or a defective heater door... Do you have any vacuum leaks? Does your HVAC system work on all modes?
Old Mar 22, 2009 | 08:11 PM
JPM's Avatar
JPM
JPM is on a distinguished road
Try back flushing the heater core and then if it still does not work try running a water hose over your thermostat housing with the rad. cap off for a few min.Keep your rpm around 1500-2000 and this should help purge the air out of the system.Just went through same thing on a 2001 Prism
TS2GFrank
May 9, 2020 05:12 PM
kevinph
Feb 25, 2019 09:24 PM
apo02
Dec 13, 2012 03:58 AM
Sterling
Apr 8, 2008 08:21 AM
strongboy2005
Feb 22, 2006 09:27 PM
