heating problems on 2000 blazer
Old Jul 27, 2010 | 12:31 AM
reidzap's Avatar
reidzap is on a distinguished road
Default heating problems on 2000 blazer
i have a 2000 blazer, i have been having some very weird problems with my truck blowing warm air. started in april i was driving to work and i noticed i had no heat when i had the dial turned to hot so i "burped" the sytem and still nothing, so i left it for a bit, then the heat all of a sudden came back, it was good for a while and now it comes and goes. the heat will be all good, then all of a sudden i wont have heat again, then it will come back whenever it feels.
DOES ANYONE HAVE ANY IDEA'S, i ahve asked many people and they have no clue.
Old Jul 27, 2010 | 06:20 AM
Possibly a plugged heater core? It is pretty easy to flush.
Old Jul 27, 2010 | 04:41 PM
reidzap's Avatar
if it was plugged i wouldnt have any heat at anytime though correct? like i stated, the heat will be good, then all of a sudden i will have no heat, then maybe a day to a couple weeks later my heat comes back to normal
Old Jul 27, 2010 | 05:30 PM
Depends. You won't know until you flush it. If nothing else, it is good preventative maintenance.
Any other symptoms? Could be the temperature control door (electronic).
Old Jul 27, 2010 | 11:42 PM
reidzap's Avatar
im thinking the heater control valve at this point but not totally sure
Old Sep 17, 2010 | 05:02 PM
xd_4_me's Avatar
xd_4_me is an unknown quantity at this point
I have similar problems with my blazer right now, only this last time the heat never came back. Did you end up trying the control valve. I took the input and output hoses off the heater core and could blow water through them, so I'm assuming it is not plugged and still no heat?
Old Oct 16, 2010 | 07:33 PM
xd_4_me's Avatar
Angry
Heat started working! ... and about two months later stopped. I blew out all the coolant lines and the heat started working, and then one day it just stopped? Would having it professionally flushed be a good idea?
Old Oct 16, 2010 | 08:20 PM
mh86334's Avatar
mh86334 is on a distinguished road
Could be a faulty blend door actuator...
Old Oct 16, 2010 | 10:59 PM
chucky blazer's Avatar
chucky blazer is on a distinguished road
I had a similar problem i would only have a little heat. my problem was no vac. from engine.
here is a canister that is vacuum fed (a ball under the hood) that may plugged. check vacuum lines from the motor to the canister. It also runs through the fender inside to the control panel
the control panel inside the truck has a rubber boot on it that has vac. hoses as well. check there for leaks. but i think u would here a hiss while driving.
my control panel leaks a little bit but i still got heat. after i got vacuum to it
the blend door i haven't ever done. but it also runs off vacuum. the valve can wear out and not hold vac. but its weird for it to work some times. unless it electrical.
hope this helps.. there is some vac. pic on this forum that are excellent.
Old Oct 17, 2010 | 10:07 AM
Crusty's Avatar
Crusty is on a distinguished road
Like mh86334; sounds allot like the blend door. Check the electrical plug behind glove compartment.
