Heavy leaking EVAP Emissions canister vent valve
Old Feb 24, 2012 | 04:15 AM
Rider's Avatar
Rider is an unknown quantity at this point
That was exactly what it was, thanks alot
And the Heavy leaking EVAP Emissions canister vent valve was the 2 same size tubes on the gastank there was reversed.
Old Feb 26, 2012 | 08:34 AM
spatula6554's Avatar
spatula6554 is on a distinguished road
The evaporative canister is a separate part than the evaporative vent valve. The canister is mounted directly behind the driver's side rear wheel. The vent valve is mounted to a frame rail above the spare tire. The canister is the heavy part with the tubes running to it...the vent valve only has one tube going to it.
Did you have to replace the canister? That sounds expensive!
Old Feb 27, 2012 | 03:28 AM
Rider's Avatar
No i just gat the tubes on the gas tank reversed and when i switched them back it all worked again
cmaddox421
Dec 29, 2013 08:33 PM
joejiz
18
Nov 14, 2012 03:31 PM
christian1984
May 30, 2012 09:32 AM
Jeru
Oct 20, 2009 08:09 PM
Havsurf
May 22, 2008 07:32 PM
