Hellllpppppp mmmmmmeeeeeee
Old Aug 1, 2017 | 03:14 PM
Rmitchell0902's Avatar
Rmitchell0902 is on a distinguished road
Angry Hellllpppppp mmmmmmeeeeeee
Ok I have a 2000 gmc jimmy SLE (2 wheel drive) and I recently replace the brake booster and master cylinder and now i can't get my vehicle out of park, my pedal goes straight to the floor but i don't hear air i check my dash board lights and the brake light along with the check engine light are on idk what to do at this point please help me also tried bleeding the brakes and that didn't help
Old Aug 1, 2017 | 08:34 PM
rok55's Avatar
rok55 is on a distinguished road
Did you bench bleed the master cylinder before install? If not, it will be extremely difficult to get the brakes working properly.
Old Aug 1, 2017 | 08:37 PM
Yes I did but I'm not worrying about the brake so much as I am about me not getting the car out of park
Old Aug 2, 2017 | 06:35 AM
newguy's Avatar
Switch under brale peddle may be bad. May have blown fuse. as for your brakes, if the fluid drained completely out. your abs needs to bleed with a tool available at dealers or it wont work right
Old Aug 2, 2017 | 10:16 AM
Which switch and I checked my fusespam they are fine and I filled master cylinder before I bench bleed it and it hasn't been empty since
Old Aug 2, 2017 | 10:28 AM
newguy's Avatar
this video will show you where it is
Old Aug 4, 2017 | 12:48 PM
LesMyer's Avatar
It's the rest of the brake system that you don't want to let air into. The ABS system has air in it, and will need the PCM aided bleeding procedure to get the air out. Tow it to a shop with a capable scanner. Pretty much any shop that does brakes these days should have it.
Old Dec 8, 2018 | 10:31 AM
I know I'm late but the switch was the problem thanks gents
Old Dec 10, 2018 | 04:08 PM
Damn late! But that's ok. I forgive you, better late then never. Lol
Old Dec 10, 2018 | 04:15 PM
Thanks for the final report. These are very helpful to others who might find this thread. And Congrats!
Blueblazer45
Apr 22, 2013 08:47 PM
mowermechanic
Jan 31, 2012 09:01 AM
neverswt
Feb 22, 2009 05:22 PM
jess1327
Mar 12, 2008 11:37 AM
Jimmiero
Aug 31, 2006 11:15 AM
