hellpp, coolant leak
Ok I have a 95 blazer and to make a long story short I'm having water leaking from the back of the motor but can't pinpoint it its not the water pump or anything like that when I looked underneath it looked as if it was running down from somewhere I couldn't see and coming off of the trans bellhousing any ideas ? I'm thinking its the intake manifold gasket but would like another persons view I also hear a whine from the front of the motor sorry ahead of time if this post is in the wrong area just really need help
Put a UV dye in the coolant, run it a little bit so it cycles through, and use a UV flashlight on the wet areas. It can help you determine how high up the leak comes from, and possibly find the are it's coming from.
