hellpp, coolant leak
Old Oct 11, 2011 | 07:09 PM
  #21
pd95blazer's Avatar
pd95blazer is on a distinguished road
Originally Posted by pettyfog
Well if it's running onto the engine mount that sure aint the intake. Unless the leak point is hidden under an accessory mount bracket and it's running around the head.
wouldn't the motor have to be running for it to be able to reach the intake though?
Old Oct 12, 2011 | 04:01 AM
  #22
swedp's Avatar
swedp is on a distinguished road
just wanna help you,i drive truck´s on the freeway´s so i´m gone inbetween. i never understod where your leak appears.if you never overboiled the motor i don´t believe in headgasket,ofcourse there could be bad casting and following crack wich mostly appears at hot engine,what about frezzeplugs? the fan blows pretty good and disorienters the leak,by pressure test you can see if pressure drops or even leakes
Old Oct 12, 2011 | 09:10 AM
  #23
pd95blazer's Avatar
the leak appears on the driver side when it first happened I lost all my coolant and it was coming down the trans bellhousing that's why I thought it was the intake manifold gasket. now its just leaking from somewhere down low and dripping onto the motor mount. This is all when the engine is off. As soon as I pour water into the radiator it starts leaking from the low point I mentioned
Old Oct 16, 2011 | 07:36 PM
  #24
maddie's dad's Avatar
maddie's dad is on a distinguished road
Hey,
It sounds like a freeze plug. I just replaced one in my daughter's 97 jimmy a couple of months ago. I'm not going to lie, it was a pain in the butt. Replacing them is not the problem, it is getting access to the plugs themselves while the motor is in the truck.
Old Oct 18, 2011 | 06:54 PM
  #25
pd95blazer's Avatar
Originally Posted by maddie's dad
Hey,
Are you talking about the freeze plug right underneath the exhaust manifold?
Old Oct 19, 2011 | 02:00 PM
  #26
swedp's Avatar
i belive that you have frezzeplug or intakemanifold driverside corner issiue,or hopefulle leaking w-pump gasket.that fan makes it it blow pretty good to disorientent you
Old Oct 19, 2011 | 02:05 PM
  #27
swedp's Avatar
on my ´99 vortec i have a very small leak at the intake corner so i have to lift the intake before this winter, i loose half a liter at 2000 km and i can see the leak from frontest bolt driver side
AcerDeucerQ
Dec 3, 2012 06:29 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
TAZ454
Jan 28, 2008 10:11 AM
dashyman
Jun 4, 2006 11:21 PM
edacsac
Feb 10, 2006 06:04 PM
