HELP 1997 blazer wont start seems to be a gas issue!
Is the ICM the thing thats attached to the coil packs bracket? cause i got the coil pack off and there also a box thing that had a wire going to it and it says GM on it.
my autozone said they test coil packs
still didnt work
i guess the guy at AZ didnt know what he was doing when he checked the coil pack or something else went out as well as the coil pack. Im going to call around today and see if i can find some one who can check the ICM and see if its bad or not. If not then i guess i will put it in the shop.
I took the ICM to advance auto they tested it it passed once failed twice they said it was bad and i spent 100 buck on a new one got home installed it and the dam thing still dont work. i give up im pulling it to the shop monday and letting them figer it out.
Ok i tested the spark plugs for spark today and its not sparking so this must be the problem. So far i changed the coil pack and ICM. Only things left is the distributor and wires and plugs which i dout its wires or plugs cause the odds of all 6 going out at once is highly unlikey. Im going to buy a distributor tommarow at the junk yard and change it. I had taken it out once already and inspected it but seen nothing wrong. is there a certin way shaft gose back into the motor cause i didnt think to see how it came out. When i put it back it it seemed it only wanted to go back in a certin way which looked the same as when i took it out.
Also the trucks computer dosent control spark dose it? just to make sure
There is most definitely a specific way the distributor has to go back in. Relying solely on the fact that it dropped back in is not a good way to go about this type of thing. I suggest you go through the EDI Engine Timing thread in its entirety, being very precise in following the steps provided.
And yes, the computer controls spark. It uses a combination of the CKP (crankshaft position - located on the timing chain cover on the front of the engine) and CMP (camshaft position - located inside the distributor) to determine the location of the cylinders, etc. It then uses that data to time the spark according to other input received from the knock, MAP, MAF, O2, and other related sensors. If you were getting no spark at all...
