HELP: 2000 S10 Oil in cooling system
Old Sep 9, 2009 | 04:17 PM
JBQ81's Avatar
JBQ81 is on a distinguished road
Angry HELP: 2000 S10 Oil in cooling system
Blown intake manifold gasket. I need torque spec and sequence. Can someone help?
Thanks,
-jerry-
Old Sep 9, 2009 | 05:04 PM
abig84's Avatar
You sure its not a crack in the oil cooler inside the radiator?
Old Sep 9, 2009 | 05:20 PM
JBQ81's Avatar
I had it diagnosed this morning and I was told it has a blown intake gasket.
Old Sep 9, 2009 | 06:04 PM
vaportrail's Avatar
vaportrail is on a distinguished road
Tighten (Lower manifold)
Tighten the bolts on the first pass in sequence (1-8) to 3 N·m (27 lb in).
Tighten the bolts on the second pass in sequence (1-8) to 12 N·m (106 lb in).
Tighten the bolts on the final pass in sequence (1-8) to 15 N·m (11 lb ft).
The sequence is as follows:
5 6
3 2
1 4
7 8
FRT
Upper manifold is 2 pass (I have not seen the sequence) of 44 in-lbf. and then 88 in-lbf. (Note in-lbf.) Not very tight. Easy to over torque and crack the plastic.
Old Sep 9, 2009 | 06:53 PM
JBQ81's Avatar
Thanks, this will help.
ComputerNerdBD
May 12, 2010 10:48 PM
rspjr0310
Jan 18, 2010 11:49 AM
gsh4386
Mar 19, 2008 08:27 AM
98SmokeBlazer
Mar 1, 2008 08:38 AM
badfxr
Jul 1, 2006 04:22 PM
