help with 4x4
#31
Reading over this thread, it just hit me, yours is a 2001 and I believe you have an electric solenoid that controls vacuum to the actuator. It looks like this:
It's located on the firewall just above the distributor and has 2 vacuum lines connected to it.
Dorman Products - Search Results
If so, with the engine at idle, one of the vacuum lines should have vacuum. If so, select 4WD and see if there is vacuum at the actuator.
#35
Getting down to the nitty gritty now.... If you're certain the axle is not engaging, either the cable is broken where it attaches to the clutch, or there's a problem with the clutch itself. The housing where the cable enters the front axle housing has to come apart to replace the cable and if the cable is OK, it will require more disassembly of the axle to diagnose & repair the clutch.
#37
The second to last sentence in my reply to that thread links to another thread which goes through the front axle engagement system.
#40
i manually put vacuum to the actuator and still didn't have 4 wheel
