Help
Old Mar 2, 2014 | 07:56 PM
bigguy68's Avatar
bigguy68 is on a distinguished road
Default Help
I have a 1995 blazer with a 4.3. i rececently replaced starter,now won't start. It cranks just fine but no start. I checked fuel pump, no pressure at test port. checked fuse and relay. I was reading about a test lead to power pump directly.i found what i think is the test lead under hood by fuseable link bar. Any help at this point would be appeciated.
Old Mar 2, 2014 | 09:36 PM
dragoon1101's Avatar
dragoon1101 is on a distinguished road
just for ***** and grins did you check all your fuses? there may be a second fuse that might be out
Old Mar 2, 2014 | 09:53 PM
richphotos's Avatar
They said they checked the fuses, I believe the test port is located on the underhood fuse panel where the relay is located...
How did you go about checking the relay?
Also, why did you replace the starter, was it having this same problem which is what cause you to think it was the starter?
Old Mar 3, 2014 | 09:55 PM
bigguy68's Avatar
Yes, checked all fuses. Also tested relay by replacing with know good one and by jumping terminals. Replaced starter due to a no start(no crank) condition. Vehicle had been running fine prior.
Old Mar 10, 2014 | 05:19 PM
In the instrument panel fuse block, check the ECM BATT, fuse #9, 20 amp fuse. Do not remove the fuse when testing. Check both terminals on the top of the fuse, (next to the amperage rating):
They must both show battery voltage at all times. Post your results.
Attached Thumbnails Help-68f3b6ff-bd00-4f90-9af7-928a9b79159e_zps62300fdc.png
Old Mar 11, 2014 | 04:48 PM
bigguy68's Avatar
checked fuse power on both sides
Old Mar 11, 2014 | 05:02 PM
Remove the fuel pump relay, check the 5 terminals in the socket, one should have battery voltage at all times.
Old Mar 11, 2014 | 06:24 PM
bigguy68's Avatar
Yes, 1 has power, used a jumper wire to each other terminal no pump running,no pressure at test port
Old Mar 11, 2014 | 06:44 PM
When you apply battery voltage to the grey wire, the pump must activate. If not, you'll need to check for voltage and ground at the fuel pump module connector. If you have voltage and ground at the module connector, the pump needs replacement.
Old Mar 11, 2014 | 11:05 PM
bigguy68's Avatar
ok, will check tomorow. Thanks for all the help
