Help, 98 to 01 conversion
Old Aug 13, 2011 | 10:00 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
Default Help, 98 to 01 conversion
I've looked on forums for info. and not exactly positive here, i have an 01 blazer that needs a motor and i have a located a reman motor from a 98 blazer my question is there gonna be a problem with the knock sensor? I know there's a diffence but will i have a problem using my sensor from the 01 into a 98 block? I also need to know if there"s anything else i'll need to swap out? Thanks in advance:icon
Old Aug 14, 2011 | 12:03 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
There was a post on here that talked about it but I couldn't find it when I just looked. But if I remember right the knock sensor won't fit into the 98 block unless you have the block machined. Someone will correct me if I'm wrong.
Old Aug 14, 2011 | 06:26 AM
coolasice's Avatar
coolasice will become famous soon enough
i thought the knock sensor only changed in 2003?
Old Aug 15, 2011 | 10:00 PM
07nhbpsi's Avatar
Ok i can use a newer block just have to drill the hole out and tap it, now my question is what is the size of the bolt? for the 2 wire sensor??? Can anyone help me???? Please I have not started this project just yet, but i got a smokin deal on a reman motor out of a 98' I am determined to make this work , was hoping someone could help me out here???? Thanks
Old Aug 16, 2011 | 12:26 AM
pettyfog's Avatar
Old Aug 17, 2011 | 07:52 PM
07nhbpsi's Avatar
Originally Posted by pettyfog
Awesome!thanks i did some searching but never found a definite answer....
Bobcat13
Nov 10, 2013 06:03 PM
914door
Dec 15, 2009 03:05 AM
cejay825
Feb 9, 2009 07:28 AM
Magnum
Sep 4, 2008 01:48 AM
2kSnakeEater
May 30, 2006 08:34 PM
