Help! 98 Blazer, No Crank No Start!!
Old Mar 8, 2012 | 05:40 PM
JustinSixx's Avatar
JustinSixx is on a distinguished road
Default Help! 98 Blazer, No Crank No Start!!
Hey guys I'm new here. But took my blazer to the hospital, and she wouldn't start back up. No crank or anything. Well I've been searching and reading your forum, and thought the culprit could be the ignition switch, until I pulled it and the contacts were not burnt? But from what I've gathered the yellow wire in the ignition circuit is what engages the starter. So I hit it with a multi meter an it only read 5 volts, not sure if that could be the issue? I've tried jumping the starter and it rolls over but doesn't fire. Anyone have any ideas?
Old Mar 8, 2012 | 05:49 PM
pettyfog's Avatar
Crank fuse in underhood fuse block 10 amp
Dont understand the 5 volts but look there first. then at ign C. And if you had ignition on while jumping solenoid to crank it should have started.
Old Mar 8, 2012 | 08:37 PM
JustinSixx's Avatar
I don't either, I mean all the other wires in that circuit are getting atleast 12 volts one was reading 15 volts? Well it was turning over but it wouldn't fire. Idk what the deal was there. I have a new ignition switch to try, but I'm not entirely convinced that's my problem. I'm 21 and have been working on vehicles since 15, so I'm pretty mechinically inclined. I have access to about any tool I need, just need advice lol. My last project was a 96 3.8 camaro, had her for two years did ALOT, two engine swaps, lots of custom stuff done. Was on 3 forums for it lol, so I'm not new to forums either.I bought a 91 syclone for $4k from my aunt, needs restored and that's why I'm trying to fix my blazer to sell to have money for my new toy.
Old Mar 8, 2012 | 08:54 PM
JustinSixx's Avatar
Looking at your pic I'm think maybe neutral safety switch, or starter relay possibly?
Old Mar 10, 2012 | 09:05 AM
JustinSixx's Avatar
Hmm so no-one at all can help me?
Old Mar 10, 2012 | 09:39 AM
spittybays
Guest
Posts: n/a
You said you have a switch, you can get to the conection block without taking that much apart. Leave the old one in place unbolt the block and bolt the new one in turn it and see if it works if not swap the relay- nobody here can do it for you- good luck- tell us what happens.
Old Apr 1, 2012 | 09:26 PM
JustinSixx's Avatar
Looks that I have to solder the new switch in right? If so an that don't fix it then I can take it back, because it will have wires soldered to it, right?
Buddykitchen
Dec 10, 2016 06:37 PM
tzimmerman77
Jan 10, 2015 03:25 PM
Travis West
Dec 31, 2012 12:54 PM
g_mike
Aug 22, 2010 02:46 PM
what?
Feb 12, 2009 08:47 PM
