help alternator problem!
Old Apr 29, 2011 | 04:04 PM
blazergurl95's Avatar
blazergurl95 is on a distinguished road
Exclamation help alternator problem!
My 1995 4.3 4x4 blazer would not hold a charge. Inspected the alternator and found that one of the wires on the plug is not going anywhere. the brown wire goes into a bunch of other misc wires and then the pink-colored wire looks like it was pulled out from somewhere and I can't find where it goes! I've looked at wiring diagrams and haven't had any luck. Any help would be appreciated, even a picture would be awesome!
Old Apr 30, 2011 | 11:08 PM
4.3l trouble's Avatar
4.3l trouble is on a distinguished road
It might be the battery Id check the voltage at idle should be around 14V my 96 has a voltmeter in the instrument cluster not sure about 95
Old May 2, 2011 | 04:30 PM
I know for sure the battery is shot. But still, the wire on the alternator needs to be fixed to keep future battery's from getting shot.
Old May 3, 2011 | 12:54 PM
Well in my 96 there's 2 wires the main positive battery cable bolts up to back of the alternator, and then one ground wire coming from the wiring harness on the side i could take and post a pic if you'd like. but i think your dealing with a bad alternator. If you can, start it and put a voltmeter on the battery and make sure your getting at least 13V from the alternator.
Maniboss
Sep 7, 2010 08:07 AM
96Blazernut
Feb 7, 2009 01:09 PM
ack
Apr 10, 2008 08:23 AM
lukewb
14
Dec 2, 2006 02:23 AM
shawnCRX
Jun 11, 2005 03:47 PM
