Help! Fuel gauge is going crazy
Old Dec 15, 2006 | 09:57 AM
02BlaserLS's Avatar
02BlaserLS is an unknown quantity at this point
Default Help! Fuel gauge is going crazy
2002 Blazer LS I've been having problems with my fuel gauge & low fuel indicatorwhen it gets down to about a 1/4 tank. - driving cross country or just from work to home - you can start the vehicle andsometimes you may 1/4 tank and the next time it will show low fuel and gauge will read E or below- then shift into neutral and it will pop back up to 1/4 tank. slaming on the brakes&side to side turns will not correct, only shifting to neutral. Sometimes backing up will also cause this to happen.The vehicle is still under extended warranty and the dealership hasn't fixed it yet. Has anyone had simular issues orknow of this? Thanks for any help / information
Old Dec 15, 2006 | 11:02 AM
rooster's Avatar
rooster is an unknown quantity at this point
Default RE: Help! Fuel gauge is going crazy
i have a 99 s10 that has a similar problem, the gauge is all over the place when i actually get low. untill then it just shows me as being low and my light doesnt always work. i dont know what causes this but several posts have been made to try and figure it out. i am assuming its a bad sending unit in the tank.
Old Dec 15, 2006 | 11:05 AM
The putting it in neutral changing the reading thing has me thinking that maybe you have a wire pinched somewhere by the shift linkage. I would get under there and check the wiring harness to the tank and make sure that it isn't damaged.
As far as inaccurate readings. I find that if I park on a hill, my reading is screwy for the first few minutes of driving, but settles back. These sending units are picky in these trucks.
Old Dec 15, 2006 | 11:46 AM
02BlaserLS's Avatar
The dash was replaced and I'm on sending unit 3 or 4 - thanks for the ideas - If the dealer fixes it I'll post what was found.
Old Dec 15, 2006 | 11:41 PM
Hanr3's Avatar
Sending unit.
Are you ready for sticker shock?
your looking at about $250-$350 to replace it. Its part of the fuel pump assembly and you ahve to replace the whole thing as one unit.
Old Dec 15, 2006 | 11:53 PM
Binz316's Avatar
Binz316 is an unknown quantity at this point
My 02' did the same thing, the dealer replaced the sending unit and it work for a little while, but has since (7 months) reverted back to its old ways. Be sure to post what they find, I may be getting a new unit as well.
Old Dec 15, 2006 | 11:55 PM
20Blazer00's Avatar
ORIGINAL: Hanr3
Sending unit.
Hanr3: The parts are available seperately if you want to do the job yourself but dealers are forcing people to buy a part that they won't need until it fails...I have found them on E-Bay for $30 - $50, AC/Delco web site has it for $70+.
Dealer will replace these parts seperately while the vehicle is under warranty so why not after???.....$$$$$$$$ cash cow...
Old Dec 18, 2006 | 08:54 AM
02BlaserLS's Avatar
Well the dealer offered this - It's normal to act this way at ofr below 1/4 tank. Just fill it up when it gets down near a 1/4 and don't shift to nuetral while your moving and you won't have this problem. A technicianalso informed me that the ECUhas a part in the fuel gauge reading( it locks out the the sending unit when the gear selector is shifted to nuetral or park something to do with anti-sloshing) I was also told that the gauge should at sometime start working again correctly once it has been locked out but not quite sure how long it may take - couple minutes, till you run out of gas, you fillthe tank above 1/4, you restart the car, or when ever it feels like working again - IT"S NORMALfor this vehical to act like this. I'm told- I guess it's to much to ask for a gas gauge that works on a 2002 year vehical. - Thanks for your guys help - Does anyone have an in with Chevy to verify this?
Old Dec 18, 2006 | 09:57 AM
Binz316's Avatar
that is a bunch of crap, I can't stand that /w my truck. SometimesI'll only put in a few gallons @ the gas station and soon as I pull out it reads empty and the low fuel light comes on. When I come to a stop and put the car into park it then reads correctly. So were just supposed to live with this defect? I'm going to talk /w my dealership and see what they say.
Old Jan 6, 2008 | 10:05 AM
jcardoza's Avatar
jcardoza is an unknown quantity at this point
Never mind.
