Help, fuel pump electrical diagnosis (1995 2WD)
Old Jul 31, 2018 | 10:53 AM
cvs's Avatar
cvs
cvs is on a distinguished road
Default Fuel pump 12v direct test?
Dear friends
I own a Blazer 1995 2WD that the fuel pump stop working. Would not energize as always (no sound) when initially turn switch on. Good cranking but no engine start.
Fuse and relay are fine.
Took tank down and now pump is out. Nothing broken in plain view
Question: Can I apply 12v directly to the pump connectors in the pump to confirm that the pump is the problem and not lack of electric power?
Thanks. Carlos
Old Jul 31, 2018 | 12:37 PM
perumotors1369's Avatar
perumotors1369 is on a distinguished road
If the pump is out it is not recommended to run it dry although I have but..why not put 4 cotter pins in the pigtail and test it with a 12v test light..should be 4 wires...2 grounds (check them both) and a 12v and a 5 volt signal (for the gauge)..good luck! Jerry
Old Jul 31, 2018 | 02:39 PM
cvs's Avatar
cvs
Will try it that way. Thanks a lot Jerry
Old Aug 22, 2018 | 11:11 PM
cvs's Avatar
cvs
Thanks again Jerry. Maybe you can help me again
I connected the pump directly to batt and pump worked ok. It expelled remaining fuel in the pump with force. Hooked 12v tester to underchassis connector that goes to the pump and is not getting current when turning key. Cable bundle plastic cover is in good shape,no cuts etc till connectors under the hood, those connectors also look fine. From there on i loose sight where the grey cable goes. Fuse and relay (exchanged to horn site and horn worked) are fine. Planning to check current at fuse box and relay ( not sure if there is a click or not). Do you know the basic fuel pump electric circuit? That grey pump cable should end in the computer?
Thanks very much
Carlos
Old Sep 3, 2018 | 05:57 PM
cvs's Avatar
cvs
Dear Jerry and friends, need help with diagnosis of fuel pump electrical supply
Fuse and relay tested fine.
Took tank down, remove fuel pump and hooked fuel pump directly to the battery and worked fine. Ejected remaining fuel at the pump with force.
Placed 12v tester at pigtail connector (grey wire is +) hanging under chassis and no voltage when ignition switch turned on.
Went to glove compartment and no voltage is getting to pump relay when switch turned on.
My diagnosis is fuel pump is not getting voltage.
Q?
If pump relay in the glove compartment is not getting 12 v, where is the voltage for the relay coming from? where should I test next to find where is the current interrupted?
(Don't have an electrical diagram)
Thanks a lot
Carlos
Old Sep 3, 2018 | 06:12 PM
cvs's Avatar
cvs
Default Help, fuel pump electrical diagnosis (1995 2WD)
Q?
Thanks a lot
Carlos
Old Sep 3, 2018 | 07:16 PM
GeorgeLG's Avatar
Do you have the "W" VIN or the "Z" Vin engine and do you have a PCM or VCM? The wiring is different.
George
Old Sep 3, 2018 | 08:20 PM
cvs's Avatar
cvs
George
my VIN at the windshield is C1S6WSV314778
That helps?
Thanks George
Old Sep 3, 2018 | 11:31 PM
GeorgeLG's Avatar
Your VIN should be 17 digits
George
Old Sep 4, 2018 | 02:06 AM
cvs's Avatar
cvs
Thanks George
Let me double check. Thats the number in the little metal plate you see thru the windshield, drivers side.
Where else in the car you find VIN? Are we looking for a "W" or "Z" in the VIN?
Carlos
