-   -   Help getting EGR tube out (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/help-getting-egr-tube-out-82461/)
ricco4592 Oct 31, 2013 06:27 PM
Hello all, new to the forum but I have found a lot of helpful information on here. I have a 2000 blazer, which I am replacing the lower intake gaskets on. I found a great thread on replacing this, but I'm having a ridiculously hard time getting the EGR tube out of the lower intake. the first time I tried, it started coming loose, but I didn't notice til about halfway through it was actually bending the tube! I really need to get this out so I can finish the project so any help would be appreciated.
Captain Hook Oct 31, 2013 08:21 PM
Use heat, PB Blaster, and a flare wrench, or a good quality, (Snap on etc) open end wrench, not a cheapie. Don't even THINK about using vice grips or a crescent wrench.
ricco4592 Oct 31, 2013 08:56 PM
will do thanks for the input. I'm assuming the actual tube isnt supposed to rotate with the threaded part right?
Captain Hook Oct 31, 2013 09:00 PM
Correct, it's a flare fitting, tube and nut are separate. Be very careful when removing, if you force it, the threads in the lower intake will strip, then you need a new manifold. Use Antiseize on the threads when reinstalling.
ricco4592 Nov 4, 2013 10:53 PM
Okay, I got the gaskets all changed out and the truck put back together. Now I'm having another problem. It's having a hard time starting. When it does, it runs okay, but it seems like its off time. I did what the write up said and mark where the dist was and the cap, but when I put it back it was a little off where it was when I pulled it. Is there any way to adjust this back with the least amount of trouble?
richphotos Nov 4, 2013 11:04 PM
dont quote me on this, but there is a brown wire under the dash on the drivers side that you unhook, unhook that and set the timing to 0° and maybe try to start it... For the love of god, I hope captain hook comes back in this thread, going to message him.
chris015 Nov 5, 2013 02:33 AM
rich,i dont think 2nd gens have the tan wire to disconnect. just the 1st gens. I believe 2nd gens are 100% computer controlled via crank sensor and cam....
captain...where ya at? LOL oh yea..its 3am,he's probably doing lower intake gaskets in his sleep.
ricco4592 Nov 5, 2013 08:16 AM
alright so I found some stuff on trying to get it to TDC so I can get this thing back where it's supposed to be. If im reading this correct, I need to take the distributor out, and rotate the little gear with a flathead to the #1 cylinder notch on the cap?
chris015 Nov 5, 2013 12:29 PM
No,remove the #1 plug. stick your finger in it. turn the crank with a socket until the piston pushes a puff of air to get it top dead center. Now,look at the distributor with the cap off. all you need to do is get that rotor button pointing towards #1 cylinder.
ricco4592 Nov 5, 2013 01:14 PM
Okay thanks a lot. This is the first time I've ever had to do this so I'm lost haha, but thanks for all the input guys.
