HELP I am lost when it comes to DTS codes
Old Feb 21, 2010 | 02:39 PM
chrishorton74's Avatar
chrishorton74 is on a distinguished road
Default HELP I am lost when it comes to DTS codes
I have a dts code in my blazer. it is a 2000 model . I keep recieving P0340 cam shaft position sensor bank 1 malfuntion. When I pull up freeze frame data this is what I get:
Calc load 23.1
st ftrm1(%) 1.5
lt ftrm1(%) 7.8
st ftrm2(%) -3.1
lt ftrm2(%) 7.8
map 20.4
rpm 1878
speed 49
maf 4.922
abslt tps 25.8
I dont know what most of this means. I am self taught when it comes to auto repair. Aslo I need to figure out where this sensor is located so i can replace it if need be. My manual says one thing and various users users say different here. I have a 4.6 liter engine. manual says on front of engine perpendicular to something and some say on distributer. where is it.
Old Feb 21, 2010 | 03:57 PM
LRV31's Avatar
LRV31 is on a distinguished road
First up if it wasn't a typo on your part you have a 4.3 engine not a 4.6.
The Camshaft Position Sensor is located in the distributor, under the cap & rotor. Remove your cap & rotor and the sensor connector and remove the 2 screws on the sensor.
Before you look to replace it however, check the connector to the sensor and the condition of the wiring.
Hope this helped.
Old Feb 21, 2010 | 04:17 PM
Old Feb 22, 2010 | 09:24 AM
Thanks for the info and you are right . I do have a 4.3 not 4.6 , I always do that for some reason. Must be from my days of drooling over stangs.
Old Feb 23, 2010 | 12:23 PM
Default still a little clueless....
Thanks again for your help, but I still have a question. what exactly does the information that I get on my freeze frame data all mean .
Old Feb 23, 2010 | 12:38 PM
They are engine operating parameters at the time the code set. While it may not be exactly 100% correct, THIS PAGE shows a list of the PIDs which should give you an idea as to what they are and further keywords you can search out if you so desire.
DetailersDomain
Detailing
Dec 4, 2011 05:19 PM
abadinalbany
Apr 16, 2011 11:31 AM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
