help i am stuck and definiatly not a mechanic
Old Dec 29, 2010 | 07:51 PM
lacuna01201's Avatar
lacuna01201 is on a distinguished road
Default help i am stuck and definiatly not a mechanic
I have just purchased (literally yesterday) a 2001 chevy blazer when i drive it there is this weird wobble in the front end. Now I have checked the lug nuts they are all tight, the air pressure is at 32lbs, and when i jack up one side to shake the tire there is only a tiny bit of movement( I am told this is ok) so i am left questioning what else could it be it does need an alignment but never have i felt a misalignment with a wobble it usually just pulls to one side i was told tie rods but there is little movement in the tire when it is off the ground is there something else i should be doing or looking at? thanks.....
you can email me at lacuna01201@yahoo.com
Old Dec 29, 2010 | 08:15 PM
abig84's Avatar
bent rim, bent bearing, busted belt in tire also ive had times leaving offroading where there will be a huge clump of mud stuck inside the rim and it can cause that too
jprife
Aug 5, 2015 01:52 PM
brettseme
Oct 12, 2010 07:00 PM
Havensk
Jul 25, 2010 08:16 PM
kawidood
Jan 28, 2007 01:24 AM
kaindragoon36
Mar 28, 2006 10:41 PM
