Help major issues
Old Jul 29, 2012 | 11:06 AM
xgiovannix12's Avatar
Have you read the other p300 thread I gave you ....
These trucks prefer ac delco for ignition parts ...
Old Jul 29, 2012 | 02:59 PM
JON27000's Avatar
JON27000 is on a distinguished road
i used ac delco plugs and wires and a dorman distributor assembly
Old Jul 29, 2012 | 03:01 PM
spittybays
Guest
Posts: n/a
When you changed icm did it come with a small packet of heat sink grease. I seem to remember a ten page thread on a p300 that finally ended with the persons module not coming with the grease. It transfers the heat to the heat sink. This guy tossed every thing but his kids at it and came down to that. Something missing from a box and 3.49 from Radio Shack.
Old Jul 29, 2012 | 03:06 PM
mychevyisntheavy's Avatar
mychevyisntheavy is on a distinguished road
if i was u i would take the icm back to were u got see if they can test it to make sure its good.
and r u sure ur not a 180 degs out on the distributor
Old Jul 29, 2012 | 08:56 PM
JON27000's Avatar
yep the icm came with the heat transferring grease i plastered it over the back and screwed it to the heat sink
Old Jul 29, 2012 | 08:57 PM
JON27000's Avatar
yep the distributor is installed properly but i'll double check it tommorrow to make sure it is
Old Jul 29, 2012 | 11:28 PM
spittybays
Guest
Posts: n/a
Hey Jon, with changing the distributor you might want to do a read on this.
https://blazerforum.com/forum/tech-a...-timing-24373/
Old Jul 30, 2012 | 03:50 AM
ynotsmyl's Avatar
ynotsmyl is on a distinguished road
make sure the distrib. is in time and not a tooth off. check to see if timing between crank and cam right and not slipped.
Old Jul 30, 2012 | 01:31 PM
JON27000's Avatar
yep as soon as i get off work ill check it out and make sure i got everything installed proper thanks for the help and ideas so far
Old Jul 30, 2012 | 04:21 PM
JON27000's Avatar
diagnosis before throwing parts..... What brand ignition products did you use ?
have you changed the cap and rotor yet ?
Have you done a leak down test yet ?
P030x - Random/Multiple Cylinder Misfire Detected
Its a common code and it can lead to many things being wrong.
Edit: This shows you the proper way to diagnose the fuel system.
96+ Fuel System Diagnosis - Blazer Forum - Chevy Blazer Forums
i went through the trouble shooting link u posted for p0300 and checked for all the items listed contaminated fuel, foulded or damaged spark plugs, damaged distributor cap, restricted exhaust. The only ones i havent check are the vcm grounds and the EGR valve and idea how i can check the grounds or the location of them? and i also double checked the installation of the distributor assembly and all is well with that.
