HELP ME! 98 Bravada
Old Mar 29, 2012 | 07:07 PM
rko42082's Avatar
rko42082 is on a distinguished road
Unhappy HELP ME! 98 Bravada
I have a 98 Bravada 4.3 Vortec that is giving me a hard time. It starts when it wants to, skips a bit as well as loss of power and gas milege...slight smell of fuel. OBD II reader says random misfires on cylinders 1 and 4. Was first told it was fuel issue. Did fuel pump...made no difference...next, the spider...again no difference. Next I was told it was a problem in the head, then told it needed a motor. Any thoughts? (have been told possibly a timing issue or icu issue. I have spare ICU that I tried. made no difference) PLEASE HELP ME!!!!!!!!!!!!!!!!!!!!!!!
Stuck in CT
Old Mar 29, 2012 | 07:12 PM
*Moving to 2nd Gen Tech* - Please read the descriptions of each of the forum sections & choose the one most appropriate to the topic you wish to post. The New Member Area is for new member introductions so you may wish to post a new 'welcome' thread in that section.
Have you done a regular tune up consisting of plugs, wires, cap & rotor?
Before jumping to the conclusion of a fuel issue, what testing was done?
Old Mar 29, 2012 | 08:14 PM
rko42082's Avatar
Yes, have done plugs, wires, cap, rotor, and checked the distributor. Fuel pressure was @ 20 with old pump...@ 60 now with new. As far as tests, I think I know about as much as the garage did...which is next to nothing lol
Old Mar 29, 2012 | 08:36 PM
What brand of parts were installed for the tune up? A lot of aftermarket caps & rotors can be bad right out of the box.
Old Mar 29, 2012 | 08:39 PM
mrkevinmjr's Avatar
mrkevinmjr is on a distinguished road
did u get a code that checked random missfire or did u just check without a light... i have a lot of shaking at idle and i wonder if im doin the same under the hood....
Old Mar 29, 2012 | 08:42 PM
rko42082's Avatar
My tester only said random misfire yes I have check engine light garage pin pointed cylinders 1 and 4
Old Mar 29, 2012 | 09:00 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
If you used anything other than AC Delco or Delphi for the tune up then that could still be your problem.
I hear NGK is alright for plugs as well
Old Apr 3, 2012 | 07:42 PM
mrkevinmjr's Avatar
i changed the ign coil with one from autozone... a duralast... is that a booboo
hubert hefner
23
Feb 12, 2011 12:58 PM
packofqtips
Mar 28, 2010 06:22 PM
demian5
Mar 7, 2010 09:00 AM
NC93BLAZERLT
21
Dec 30, 2008 05:23 PM
Slick
Lowering Tech
Dec 8, 2008 09:32 PM
