Help me please! 99 bravada wont shift/ no speedo....
Old Feb 12, 2011 | 11:22 AM
  #21
Only the 98+ trucks have an underhood fuse box.
Test for continuity between from the connector at the VSS to the other end of the wires at the PCM. They are on connector 1, pins 29 (light green with black stripe) and 30 (purple with white stripe).
You didn't happen to pinch the harness between the engine & transmission did you? That has come up a few times here.
Old Feb 12, 2011 | 11:35 AM
  #22
marked0210's Avatar
marked0210 is on a distinguished road
yes i checked for pinching, i will now check the continuity per your instructions
i hope this will work! i really appreciate all your help, you really know your stuff!
ok now when i check for continuity on those wires the multimeter beeps when i touch either wire. i have it hooked up to the green wire and it beeps when i touch pin 29 and 30 and vice-versa with the purple wire.
does that mean the wires are touching somewhere?
Last edited by swartlkk; Feb 12, 2011 at 12:53 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Feb 12, 2011 | 12:55 PM
  #23
That means that there is continuity across the VSS sensor itself which is good. There needs to be around 1700-2400 ohms resistance across those wires. Check that next. Then, there should be a few volts AC voltage when you rotate the driveshaft (truck in the air on jack stands).
BTW, please do not respond multiple times in a row. Quick, consecutive posts is prohibited by the rules of the forum (rule #4). Post back when you have results and/or a new question and wait for a response. If you need to ask another question and another member has not yet replied, please edit your post. If you have waited for ~24hrs without getting a response, it is then permissible to post again.
Old Feb 12, 2011 | 12:58 PM
  #24
marked0210's Avatar
i have the meter touching the green wire and it beeps when i touch both pins 29 and 30. same for when i'm checking the purple wire both pins beep. does that mean the wires are touching somewhere?
ok when checking for the ohm output i check it at the vss contact pins right? i had it set at 2k and it read 1,300.
Last edited by swartlkk; Feb 12, 2011 at 07:10 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
S10BlazerFTW
Jun 16, 2013 03:35 PM
guitarman1961
Apr 7, 2013 08:00 AM
nikch86
May 4, 2011 11:04 AM
ImScrewed92
Tires and Wheels
25
Jan 31, 2010 04:12 PM
bigdawgz2006
Nov 21, 2009 02:44 PM
