Help Please
Hello all...about 2 months ago my 2001 Chevy Blazer with a 4.3...V6 Vortec 4 wheel driver..was running good. It soon wouldnt start..but would almost start and hit 1k RPM then bog out. I checked the cap and rotor and was getting no spark. So i replaced the plugs cap rotor and wires and was getting spark, and it would still not start. I also replaced the camshaft sensor,crankshaft sensor and the Central Port Injector. i am getting gas from the fuel pump into the engine..i need some help I cant think of anything else
are you sure the ignition is timed right?
if you have the correct fuel psi, air and spark and it still doesn't start then it is a compression issue. If it is timed right, then you will need to check compression. YOu can rent the compression gauge from Autozone.
