HELP!!! Problem with brakes!!!!
Old Jul 28, 2010 | 05:12 PM
bugsbunny16374's Avatar
bugsbunny16374 is on a distinguished road
Cool HELP!!! Problem with brakes!!!!
Have a 1999 with brake problems. Have no pressure. Pedal goes all the way to the floor. Replaced master cylinder to no avail. Have bled all calipers and no air in the lines. When I do apply the brakes, sounds like metal on metal. Pads are like new!! When the brakes are applied looks like the calipers are working, you can see them move.
Old Jul 28, 2010 | 05:38 PM
*Moving to 2nd Gen Tech* - The Forum Help & Suggestions Center is for questions about the use of the forum and/or suggestions for making it better.
Did you make sure to fully bench bleed the replacement master cylinder before you installed it?
Old Jul 28, 2010 | 06:44 PM
yes i did.
Old Jul 28, 2010 | 06:49 PM
Sounds like you either have a bad master cylinder or still have air in the master cylinder.
Old Jul 28, 2010 | 07:02 PM
Topsecret66's Avatar
Banned
Topsecret66 is on a distinguished road
Agreed.
Old Jul 28, 2010 | 08:18 PM
I don't see how it can be the master cylinder. Every time a bleed the brakes, the fluid level in the reservoir drops.
Old Jul 28, 2010 | 09:11 PM
cbr995's Avatar
I've bought a brand new master cylinder before that was busted. Happened to our 'Burb.
Old Jul 28, 2010 | 09:17 PM
A drop in fluid level does not prove or disprove anything that I have said... You can have a bad master cylinder (with a leaky seal) that will still push fluid out when a bleeder is opened. It will still hold a bit of pressure in the lines, just not what it is intended to deliver.
And air in the master cylinder can still be a problem. You may not be pushing the master cylinder through a full stroke when using the brake pedal. That is why it is always recommended to bench bleed the MC so you can ensure that you are working the MC fully.
Old Jul 29, 2010 | 05:33 PM
Yea. After I thought about it, even if there is air in the mc, the booster should press the air out, thus dropping the fluid level. My bad. I'm going to keep bleeding the lines and hope that the problem rectifies itself.
Old Jul 29, 2010 | 07:07 PM
Ok, have bled the lines (again for the 3rd time) with the same results. Took off the mc and bench bled it a second time, same results. Pedal still goes to the floor. When I was bleeding the left front, I watched the reservoir and saw it gurgle. I don't think it's to be doing that. Bad mc or maybe the o-rings?
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
tiggermosh
Sep 7, 2009 10:43 PM
