Help with rear disc brakes
Old Mar 18, 2018 | 03:45 PM
Krmnnghia's Avatar
Krmnnghia is on a distinguished road
Default Help with rear disc brakes
Working on a 2000 Bravada. Complaint of rear brake noise. Both calipers were completely locked up and grinding away. Replaced the rear caliper, pads, and rubber lines. When Disconnecting the factory rubber lines I was getting fluid out of the hard lines on both sides. Went to bleed the system and I can get barely any fluid to come out of both of them. With the bleeders closed, the pistons are not moving.
Possibly have a clogged hard line somewhere?
Both new calipers or both new rubber lines are bad?
Something I am missing because I have never done brakes on this car before?
Thanks!
Old Mar 18, 2018 | 05:46 PM
The last time I saw those symptoms, somebody had put ATF in the master cylinder and ruined every rubber part in the brake system. Hopefully that's not what you're dealing with.
Old Mar 18, 2018 | 06:45 PM
Krmnnghia's Avatar
WOW. Yah that is definitely not what is going on here. I am the only one that ever does work on this vehicle.
Reading some threads here a lot of folks are saying to gravity bleed both new calipers for roughly 5 minutes. I had not attempted that yet so I will do it tonight and see what happens. I did pump the brakes a few times in my attempt to bleed them so hopefully I don't have an issue after that.
Old Mar 19, 2018 | 02:19 AM
newguy's Avatar
only pump the brakes when the bleeder valve is closed. Pump, pump pump, hold the brake peddle down, have someone open the bleeder valve then retighten , repeat until there`s no air coming out. Keep brake fluid res, full
Old Mar 19, 2018 | 07:47 AM
LesMyer's Avatar
Did you let the master cylinder run out of brake fluid (for rear brakes) while changing the calipers? If so you probably have air in the ABS system and will most likely require the brake bleeding to be performed using a capable scanner.
Old Mar 19, 2018 | 07:50 AM
Krmnnghia's Avatar
No I did not let it run dry. I did suck out all the fluid from the master and refill with new DOT3, but did not pump the brakes at all during that process.
Old Mar 19, 2018 | 05:28 PM
LesMyer's Avatar
I'm sorry but it really sounds like air in the system.
Old Mar 19, 2018 | 05:37 PM
Krmnnghia's Avatar
So I had the wife help me after work today. Gravity bled for 10 minutes each side. Then did the standard press and hold method of bleeding with the car off. This feels like normal with the 3rd pump being very stiff. Was able to get air out of both sides this way.
I still cannot get the caliper piston to move on either one. So frustrating. Had my wife start the vehicle and when its running the brake goes to the floor. No pressure feeling in the back calipers but the fronts do hold.
I am at a loss.
Old Mar 19, 2018 | 07:38 PM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
Thanks!
You need to get together with
stevbre1 He is dealing with the same type of problems https://blazerforum.com/forum/builds...olorado-95738/
Old Mar 20, 2018 | 03:01 PM
Tajohns34's Avatar
The last time that I did rear calipers I gravity bled them for about 15 minutes each because I wanted to flush it. I just made sure I kept the reservoir full and all was good.
