HELP! Replaced intake manifold gasket - have problems now.
I just replaced my intake manifold gasket and MAP sensor on my 2000 Blazer. I put it all back together as per the directions. I started my truck and the engine has a miss. The check engine light is also on.
Okaaay? What are your code's? What cyl# is missing? And did you put the distributer in right or 180 off? AND did you make sure all the plug's went back in there right spot's? All these will play factor in to your engine missing.
Check for vacuum leaks.
When you removed everything, did you open up the intake plenum or pull it off complete? Pull the electrical connection to the injection spider and have a look at all of the pins. It is not too difficult to bend a pin. |
dist in right mark rotor and dist housing to make sure it was.also all plug are in right spots triple check eveything. i will find out code today.
when you say intake pelnum what do you mean? i took everything off include tb and cai. all i did was loosing fuel and sensors and took dist out but mark it correctly. |
What I meant by open up the plenum was the removal of the plastic upper intake. If you left that as an assembly with the lower intake, then we can rule out an issue with the injection spider aside from the aforementioned bent pin on the main electrical connection to the spider.
You can check for vacuum leaks with an unlit propane torch. Also check to make sure you have all of the spark plug wires fully seated onto the distributor and the plugs. I have seen trapped air in the boot cause a plug wire to become disconnected. |
Originally Posted by swartlkk
(Post 288620)
i also replace ign module to because went bad a couple weeks ago. wondering if coil is bad to, because when i give it some gas in higher rpms it smooth out.
That sounds like a bad cap or rotor. Mine was doing something similar. Cap and rotor sorted it out.
did you do your intake to? and did this happen?
Go to Autozone and get that code read. You'll get better help with a solid clue.
| All times are GMT -5. The time now is 02:10 AM. |
