HELP! Replaced intake manifold gasket - have problems now.
Did you notice that what I posted was links??? Links to the actual diagnosis for the codes you have... Cause if you have done everything that is listed, you would have found the source of the problem and repaired it by now.
I had the same problem when I fixed my lower intake last year. I replaced the spider and after the new one was all tucked away and the truck was runing I noticed that a pins was bent on the old one. I'd check them quick so you can rule that out if anything.
I belive it is right in front of where the fuel lines go into the spider. It should have a blue pin that holds it in that you have to remove to get it off just be carefull and pull it straight up. Then look to make sure you dont have any bent pins in there.
