Help with replacing lifters
Old Jun 28, 2011 | 03:54 PM
tony991's Avatar
tony991 is on a distinguished road
Default Help with replacing lifters
Does anyone have any info on replacing lifters? Any tips or tricks? I have to replace the lifters in my 1998 4.3 blazer.
Old Jun 28, 2011 | 05:40 PM
You'll need to pull the intake manifold and the valve covers. You can then remove the rocker arms, push rods, and pull the lifters out.
What makes you think you have to replace the lifters? If you have some valve tick, you may want to first make sure that the rocker arms are tight. You only have to remove the valve covers for this. You'll have to rotate the engine over to ensure that the lifters are on the cam base circle (all the way down) before you can torque the rocker arm bolt for that valve. While you are there, you may want to pull each push rod and make sure that it isn't bent by rolling it on a piece of flat glass.
Old Jun 28, 2011 | 08:04 PM
BUBBA3M's Avatar
BUBBA3M is on a distinguished road
I replaced the lifters only, on a 1955 Chevy and the cam went flat within 200 miles. Just a thought.
Old Jun 29, 2011 | 10:59 AM
pheaton's Avatar
pheaton is on a distinguished road
I think it's pretty straight forward. The fuel lines don't really like to move, but that's about the biggest thing you would run into. Plus just the annoyance of taking hoses and throttle cables and things like that off. Not difficult, just a bit time consuming.
I'm also curious to know why you think you need lifters? Have you been that far into the engine lately? If you have other issues it would be a good time to fix them. LIM gasket, clean or replace the spider, etc...
Dadatone
42
Feb 24, 2013 09:08 PM
knyterspyder
Sep 27, 2010 08:49 PM
kbaker308
Lifting Tech
17
Jan 17, 2009 03:01 PM
im2ys4it
Mar 30, 2008 07:58 PM
chevy_kalle
Dec 8, 2006 03:24 PM
