help with trouble codes PLESE!
Old Oct 7, 2010 | 01:44 PM
redDragon96's Avatar
redDragon96 is on a distinguished road
Default help with trouble codes PLESE!
the ses light came on in my 96 4door blazer today. so i went down to murrays pulledthe codes and came up with 3. the first is p0147 wich is o2 heater (bank 1 senser 3). the other 2 are p0700 trans control system malfunction. the other is p1100 and i have no idea what it is for. any help with these codes would be great! thanks i appreciate it!
Old Oct 7, 2010 | 01:49 PM
P0147 -- Heater Circuit B1S3 (post-cat O2 sensor) - use the troubleshooting steps found in the P0135 - HO2S Heater Circuit Bank 1 Sensor 1 thread to diagnose. You could also switch the B1S2 & B1S3 sensors (pre & post cat respectively) and see if the code changes.
P0700 is a generic code... Are you sure there were no other P07xx codes?
P1100 -- Mass Air Flow sensor circuit intermittent - I would inspect the wiring to the MAF sensor which is located in the intake duct between the throttle body and the air filter housing.
Old Oct 7, 2010 | 02:27 PM
no those are the only codes. thank you will inspect the wiring and maf. i have a new o2 senser in the garge. probably goingto swap them out tomorrow. thank you!
abadinalbany
Apr 16, 2011 11:31 AM
bigjoewebb
Jan 27, 2009 09:36 AM
CorrosiveMind103
Nov 7, 2007 08:03 PM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
