Help with vehicle RS not working please?
Old Jan 21, 2010 | 07:24 PM
dunontme's Avatar
dunontme is an unknown quantity at this point
Default Help with vehicle RS not working please?
I have this posted int the "sight&sound" area for a couple days and havenot got any replys so I'll see if any one here can help. The vehicle is 1998 chevy s blazer with passlock 2 and no factory alarm. The equipment is prestige APS-920a and DEI 555LW bypass. I wired everything using this diagram http://www.the12volt.com/installbay/...etail/435.html and this is the alarm wiring http://audiovox2.info/docs/voxx_mob/...920_DOC_IM.PDF . I ran the blue wire from the 555lw to the Light Blue Wire: Ground Output While Running Under Remote Start. I have the Brown w/ black Trace Wire: Negative Inhibit Input Plus Trigger When Armed going to the white brake wire. I have programed the 555lw as instructed and the alarms tach learn feature and everythings led's flashed like they should.. The problem is when I press the trunk/start button twice to remote start nothing at all happens? Do I need to wire anything to the 4 Pin Auxiliary Output Harness, Connector “A”? The auxiliary 4 pin connector provides low current outputs to control various functions in the vehicle during different stages of the Remote Start unit's operation.
Old Jan 21, 2010 | 07:34 PM
*Thread Closed - Double Post*
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
IndianaBlazerGirl
Dec 29, 2010 11:37 AM
bootlegger
Dec 14, 2010 05:18 PM
218persuader
Aug 20, 2010 06:11 PM
