HElP very strange fuel issues on 98
#21
Well i got it to start up it to a few times turning the switch on and off for the fuel pressure to raise up past 50 which will allow it to start. i gently rev'd the engine a little, left it alone to idle then the fuel pressure dropped, engine shut off and now there is now fuel pressure or fuel pump action at all. i tested the voltage going in to the pump and it hit 12 volts for the 2 seconds after ignition turn on and off. SO I Figure it is likely the fuel pump. I probably didn't need to replace the regulator but i did clean out the fuel system and throttle body and intake mani while I had it taken apart. And the cleaning was badly needed. time to get a good quality fuel pump now. I have a 1 year warranty on the pump i bought on ebay, it may cost me shipping to get it replaced through there. A friend's wife has a 98 s10 and had to replace her pump 7 times in a 4 yr period. If i can get a good discount I may just buy one from a local store.
#22
Do yourself a favor and do not follow in the footsteps of your friend's wife. Get an AC Delco pump. No substitutes.
#23
As far as the spark plug goes listen to swartlkk simple swivel extension will get her out with a little trouble but not much leave that rod alone
![Smile](https://blazerforum.com/forum/images/smilies/smile.gif)
postal0dude
36
04-28-2013 10:03 PM
pardyryan
11-29-2011 08:27 PM
Scream And Fly
05-16-2009 03:56 PM
