Hi All blazer brakes stumpd
Old Dec 6, 2011 | 06:25 PM
GMCrazy14's Avatar
GMCrazy14 is on a distinguished road
Default Hi All blazer brakes stumpd
Just pikd up a 2000 blazer 124k i test drove it and didnt notice anything wrong, wife starts driving it and she tells me somethin wrong w brakes so i drive it and when you come up to a stop feels like it has traction control or somethin u feel pedal pulsate 2 maybe 3 times then stops only happens when u are almost stopped. Havent had achance to take the wheels off yet no abs light on either just wonderin if anybodys had this happen. This is my third blazer and never seen this bfore. Thanks
Old Dec 6, 2011 | 06:46 PM
warthogdriver's Avatar
i had something similar happen to me...its most likely your abs sensors on the wheel hub. check them at the wheel and at the harness connection on frame.
i am guessing you have 4wheel though.....like me.
Old Dec 6, 2011 | 06:58 PM
GMCrazy14's Avatar
Yup its 4 wheel drive would the sensors throw the ABS light on or not the sensor is behind the disk right gonna take wheels off tomrow got home 2 late 2nite thanks
Old Dec 6, 2011 | 07:00 PM
antman94's Avatar
antman94 is on a distinguished road
x2 on abs sensors. Check the wires leading to the abs sensors to make sure there are no frayed or broken wires, then turn to the sensor itself.
Old Dec 6, 2011 | 07:10 PM
abig84's Avatar
yep typical chevy issue. see it on s10s and fullsizes. probably one truck comes in the shop about every other week for the same issue. if you have a really good ob2 scanner with a datastream where you can see the wheel speeds you can usually see which one it is thats not working properly. it usually wont register speed untill about 10mph. or when it starts to get worse its gonna pull the opposite way when you apply the brakes. so if your right one is bad it will pull to the left cause the right has the abs going off
the way to fix it is take off your caliper and rotor then unscrew the allan head holding in the abs sensor and wire brush down the surface or use a grinder of some sort if its really a rotted mess. fixes it everytime
only down side is theres about a 50/50 shot that the wire is going to break off in there. the bearing develops a rust ring at the top of the hole and makes it hard to get it out in one piece. if thats the case then you have to buy a new wire and/or bearing BUT thats really the right to fix it anyways
Old Dec 6, 2011 | 07:20 PM
GMCrazy14's Avatar
Thanks 4 all the replys takn wheels off 2mrow will let u no wats up
Old Dec 6, 2011 | 07:39 PM
Here's a link to the GM TSB explaining the proper way to diagnose & repair it:
https://blazerforum.com/forum/tech-a...ment%5D-26941/
Old Dec 7, 2011 | 09:50 PM
nxsmstng's Avatar
nxsmstng is on a distinguished road
yeah, i have alldata pro and there is a technical bulletin from GM and the above link is what i have! btw, this is happening to me to but i just pulled the fuse, works great without abs!
Old Dec 8, 2011 | 04:40 PM
GMCrazy14's Avatar
Tore brakes all aprt cleaned sensors same thing happens I'm pullin fuse 4 now thanks 4 all the replys
Old Dec 9, 2011 | 02:53 PM
Did you check voltage at both front sensors as outlined in the TSB?
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
maipoxx
May 20, 2013 10:15 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
