"hiccup" at highway speeds?
Hi folks,
Noticed yesterday on a drive from Houston back to Austin that my 2001 Blazer would occasionally have a "hiccup" or feel like maybe it was dropping a cylinder every now and then. Funny thing is, that when I got home and went out later in the evening, it didn't do it, and it hasn't done it this morning.
I am planning on doing a tune-up, as it runs a little rough at idle and I don't know when it was done last (just got the vehicle).
Any ideas about what the issue is? Hoping a tune-up will solve it.
Thanks
Craig
Thanks
Craig
Check your distributors you can have a misfire without triggering a check engine light it has to register as a fault for a certain amount of times before the light comes on. I had the same problem sometimes the light would be on when it would miss really bad after babying it I could get it to shut off but if I hammered on it to hard it would trigger it cause my dist gear was only wore down on about a quarter of it and at that time I had no idea what was causing it and never thought it could be something so simple. it's worth checking out.
My 02 had the hiccup you describe when cruising on the freeway. I pulled the code for a misfire on cylinder 4 so I did a full tune up and it still didn't go away. Everyone I talked to said it was the injectors at that point. Rather than replacing the injectors, I run the Lucas fuel injector cleaner at every other fill up and the hiccup hasn't returned.
tazz9690
91
11-21-2020 05:04 PM
Scoody Boo
01-17-2007 03:14 PM
