High rpm at Idle
Old Feb 1, 2017 | 08:01 PM
Graveyard's Avatar
Graveyard is on a distinguished road
Default High rpm at Idle
Hello,
Just wondering, what would cause 1200 rpm idle? O2 sensor or I did have a code for a low voltage error for my throttle position sensor.
Anybody have some suggestions?
Thanks
Old Feb 1, 2017 | 09:20 PM
LesMyer's Avatar
Originally Posted by Graveyard
Hello,
Thanks
Probably engine needs to know when the throttle is closed before it will adjust idle down with the IAC motor.
Old Feb 2, 2017 | 01:36 AM
kurfbird's Avatar
kurfbird is on a distinguished road
Mine was a bad fuel spider
Old Feb 2, 2017 | 08:19 AM
Graveyard's Avatar
Alrighty then, thank you Guys!
Hey Les, here are the codes I pulled up this morning...
p1122 throttle position sensor circuit (intermittent low voltage)
p1406 exhaust gas recirculation position sensor performance
I recently pulled the egr valve and cleaned and blow it out with air.
Sprayed it with cleaner first.
Later Guys
Old Feb 2, 2017 | 09:02 AM
LesMyer's Avatar
https://blazerforum.com/forum/tech-a...agnosis-26408/
Both of the codes you mentioned are listed here. Read the descriptions and especially the diagnostic aids. Then it will become apparent which PIDs you can monitor using Dash Command to help identify the problem. I believe you should have TPS and both commanded and actual EGR position in Dash Command. Please ask any questions that you might have. Good luck!
ps. if EGR was stuck open, that could cause a high idle and also could set a P1406.
Old Feb 2, 2017 | 10:56 AM
Graveyard's Avatar
At work now but later I may need to call on ya to setup some gauges on dash commander. It's been a while since I've done any gauges...
Thx
Old Feb 5, 2017 | 08:08 AM
Graveyard's Avatar
Okay, installed a new Throttle position sensor. Wow, what a nice difference that made. It didn't completely correct my issues but it helped greatly!
I also had a lot of shaking due to bad rotors on the front. I replaced those also.
It smoothed my braking so nice...should have done that a year ago.
Best money I've spent in a long time!!
Later Guys
Old Feb 5, 2017 | 10:22 AM
LesMyer's Avatar
Later Guys
glad you got things worked out to your satisfaction.
Old Feb 6, 2017 | 07:43 AM
Graveyard's Avatar
Oh yeah, finally
I may have to change it's nickname now...lol
Something besides bluebomb. I put the spit shine on it yesterday.
Later
Old Feb 8, 2017 | 12:18 PM
Graveyard's Avatar
Hey, one more question for now. If the "IAC" were to begin to go bad, It wouldn't affect anything at highway speeds would it?
Later
