hood latch 2002 cable? Help
Old Nov 12, 2012 | 12:26 PM
sportf190's Avatar
sportf190 is on a distinguished road
Default hood latch 2002 cable? Help
Hey Guys I have attached a picture to show you but basically I have a cable that is broke, we had to cut it to open the hood. Now how do I fix this? I am thinking a junkyard will have the part but do i Just need the cable or the whole latch? I think it was attached to this metal piece so I am thinking it is a whole part correct? I have a 2002 chevy sport 2 door.. thanks!
Old Nov 12, 2012 | 02:10 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
if I'm not mistaken you can remove the cable from the under hood latch but then must remove the rest of it from the interior as a whole piece
Old Nov 12, 2012 | 04:00 PM
newguy's Avatar
you can get just the cable
Old Nov 12, 2012 | 05:28 PM
sportf190's Avatar
That is what I thought but it seems like it was attached to that latch.. how do I get it off that latch that pops the hood.?
Old Nov 12, 2012 | 05:59 PM
newguy's Avatar
It should just pull out. The rubber boot holding the cable should push out sideways
Old Nov 13, 2012 | 10:42 AM
sportf190's Avatar
ok guys here is what I am dealing with you can see the broken cable off on the right end.. This part is not coming off so if I go to the junkyard what would I need and also how do I get this cable off because I won't need this new metal piece right just the cable and latch?
Old Nov 13, 2012 | 11:16 AM
newguy's Avatar
Lay it down, put a screwdriver on the rubber part and hit the handle of the screwdriver with a hammer, it will come off. And get a new cable from an auto parts store
Old Nov 13, 2012 | 11:24 AM
sportf190's Avatar
gotcha thanks a lot! And how does the cable connect to the thing that releases the hood? is there any diagrams so I know when I buy the new cable where to put it into. Also I don't need a new latch from the inside right? the cable from the store will attach to the inside lever and to this piece..?
Old Nov 13, 2012 | 12:05 PM
newguy's Avatar
The new cable comes with a lever, look for where the old cable went through the firewall also. The cable will have a piece metal on the end hooks into the bent over piece on the hood latch
Old Nov 13, 2012 | 12:11 PM
sportf190's Avatar
New Hood Release Cable Lever Handle Chevy S10 Truck Sonoma 94 04 Blazer 95 05 | eBay
would something like this work? is that my cheapest option?
Thanks!
