Hot in blazer all the time
Hi guys little problum its be 80 the last 2 days and I noticed it gets real hot inside all the time even with everything trund off like heater is on all the time can even feel hot air blowing in at my feet somtimes. Also noticed ac just blows hot air and it worked last year any Ideas????
one thing to check is that at least with mine is that if you have the temperature control (mine is a manual dial slider thingie) on heat it will move at least some hot air out of the heater. if the a/c doesnt blow cold check the coolant in the compressor. oh does the compressor work? mine cycles on and off every couple seconds. it blows cold air buti can feel it warm up slightly when it cycles off. other people can probably help you more but this might get you off to a good start.
FT III
Jun 29, 2015 09:51 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
