How to change the coolant in 95 blazer?
Old Oct 11, 2009 | 10:52 AM
riverjamie's Avatar
riverjamie is an unknown quantity at this point
Default How to change the coolant in 95 blazer?
What's the best method to change the coolant? I had a problem with overheating. I found that the water pump was leaking. So today going to change water pump, thermosat, and radiator cap. Upper and lower radiator hoses and heater hoses were changed 30k ago. The lower has a coil in it, but the upper does not. Is this normal? I'm also considering replacing the fan clutch because I think it is not working at times. BUT my main concern is changing out the coolant. I've heard it can really be a problem to get all the air out? Any help would be appreciated. Thanks
Old Oct 11, 2009 | 10:57 AM
rriddle3's Avatar
Raise the front end with the passenger side slightly higher, radiator cap off, run the engine up to operating temp and watch for air bubbles coming out. When they stop, turn it off, add coolant as necessary and let it cool down. Repeat a second time to be sure the air is out.
Old Oct 11, 2009 | 03:27 PM
Jason Rebellion's Avatar
Jason Rebellion is on a distinguished road
take the radiator cap off and open up the valve on the bottom of the radiator. then do what he said ^^^^ to fill it back up.
AcerDeucerQ
Dec 3, 2012 06:29 AM
Hormisdas
Nov 27, 2012 09:42 PM
dj00140
Apr 26, 2011 06:00 PM
dbleon
Dec 25, 2007 04:04 PM
jdw1529
Oct 30, 2007 12:04 AM
