How do i replace the ignition control module on my 95 blazer
Old Feb 6, 2019 | 08:22 PM
Flcountrygirl8248's Avatar
Flcountrygirl8248 is on a distinguished road
Default How do i replace the ignition control module on my 95 blazer
I have a 95 blazer 4.3L. I am getting no spark in the coil or the spark plug wires. We replaced the coil the distributor cap and rotor button. Replacing the wires and was told it could be the ignition control module. Help??!!
Old Feb 6, 2019 | 08:30 PM
All depends on what ignition system your truck has. If the plug wires press down into the top of the distributor cap, the ICM is mounted in the bottom of the distributor below the rotor. If the plug wires come into the sides of the distributor cap (horizontally), then I believe the ICM will be mounted on the same bracket as the coil.
Old Feb 7, 2019 | 07:35 AM
cleburne red's Avatar
Correct. I have a 95 with the horizontal plug wires. The icm is a separate piece, mounted on the same bracket as the ignition coil
Old Feb 7, 2019 | 08:23 AM
Good to hear! It's been a while since I have been under the hood of the many variations that GM crammed into the '95 s-series. Glad to see that I still remember correctly!
Old Feb 7, 2019 | 09:08 PM
stonum's Avatar
stonum is on a distinguished road
If your 1995 is the same as my 1999, you should also get a tube of thermal paste to spread on the surface of the ICM that mates with the heat sink. This is for efficient heat dissipation. I use this stuff...…
https://www.amazon.com/gp/product/B0087X728K/ref=ppx_yo_dt_b_asin_title_o00__o00_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0087X728K/ref=ppx_yo_dt_b_asin_title_o00__o00_s00?ie=UTF8&psc=1
….(Arctic Silver 5 AS5-3.5G Thermal Paste) if it's cold outside where you are, bring the assembly inside so the paste will spread on easily.
jatkins3983
May 28, 2024 11:15 PM
Kaput
13
Jan 16, 2011 05:41 PM
Milwaukeedude
Oct 14, 2009 10:48 PM
flabob1
Dec 2, 2008 04:17 PM
84 Blazer
Dec 6, 2007 09:27 PM
