How in hell plug
Old Feb 21, 2009 | 11:30 AM
2009ec's Avatar
2009ec is an unknown quantity at this point
Default How in hell plug
I was doing some basic maintenance on my 01 blazer (4.3l). On my agenda was to flush the radiator. I couldn't find any similar posts on this topic but first off it took me forever to locate what i believe to be the drain plug. if any1 could confirm or advise. It appeared to be located on the passenger side or the radiator directly below the bottom hose. If true are there any good techniques to turning the thing. I couldn't come up with any good plans on how to do so.
Old Feb 21, 2009 | 12:01 PM
dBsound's Avatar
dBsound is an unknown quantity at this point
Default RE: How in hell plug
I ended up just removing the bottom hose. I got tired of trying to turn it.
Old Feb 21, 2009 | 12:25 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Insert a 1/4" drive ratchet or short extension into the plug, turn counterclockwise about a 1/4 turn and pull out on the plug.
Old Feb 21, 2009 | 05:40 PM
WolfPack's Avatar
I thought they did away with the drain plug in 2000 or 2001? Are you sure youve found the drain plug...?
Old Feb 23, 2009 | 12:57 AM
AJBert's Avatar
Yes, there is a drain plug and it is a PITA. I found it much easier to pull the lower hose rather than risking breaking that plastic petcock valve.
Old Feb 23, 2009 | 01:59 AM
bandidolenny's Avatar
Of course when pulling the hose you gotta be careful not to break the radiator itself... seems the older the radiator the easier they break.
Old Feb 23, 2009 | 09:32 AM
BlazinMike89's Avatar
BlazinMike89 is an unknown quantity at this point
I just pull my hoses off, the stupid drain valve empties it slow and id rather just pull my hoses and let any crap out.
futuredoc
Oct 7, 2024 06:14 PM
4.3l trouble
Apr 7, 2019 06:54 PM
speedfreak81
Oct 13, 2009 06:58 AM
boulonman
Mar 5, 2007 05:10 AM
swoopes_30
Feb 20, 2006 02:33 PM
