how high
Old Jan 12, 2007 | 02:23 AM
tammikm's Avatar
tammikm is an unknown quantity at this point
Default how high
how high does a stock blazer sit off the ground, measuring from the front and rear wheelwell?
Old Jan 12, 2007 | 04:25 AM
Chevy Lover's Avatar
Default RE: how high
What year..
Old Jan 12, 2007 | 11:27 AM
rooster's Avatar
rooster is an unknown quantity at this point
also measure from frame to ground near the wheels.
Old Jan 12, 2007 | 11:31 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
Pulling from your past posting:
I run regular GM oil in my blazer, its a 2001 4x4
Is this theone that you are asking about?
Or are you asking in general due each generation is designed differently.
Old Jan 12, 2007 | 03:01 PM
tammikm's Avatar
2001 blazer, It looks to me like it is sitting lower than other blazers
Old Jan 12, 2007 | 03:13 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
minimum ground clearance is 7.5"
maximum ground clearance is 8.3"
here.... this will give you about any dimension or spec on the blazer you could wanna know.... this is for a 2001 4 door 4x4... .but it can be changed....
LINK
p.s. mods, how do I make the link smaller? before the site changes I could, but I cant now??
EDIT by m00nwater Hmmm...I can't get it to go for some reason either.
EDIT 2...OK...now I got it to work. I had to copy and paste your link to get it to work. You have to do it like this:
ADD YOUR TEXT FOR LINK
Old Jan 12, 2007 | 03:27 PM
tammikm's Avatar
ok thanks, I was just wondering if someone could measure from the front wheel well to the ground and same on the rear, I had new shocks put in a year ago but it seems to sit low compared to others i see.
thanks again
Old Jan 12, 2007 | 03:30 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
To make the link smaller just make text like "Click Here" then just high light that text and click on the hyperlink button and a window will open. Put that long url in that window that pops up and click ok. Now when you click submit people will be brought to that long link when clicking "Click Here"
Old Jan 12, 2007 | 03:32 PM
^^^Nice find!!!
Old Jan 12, 2007 | 03:34 PM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Ahhh...I didn't see that...I always do it manually.
