how long to clear codes?
Old Mar 20, 2012 | 09:24 PM
thebigjimmy's Avatar
thebigjimmy is an unknown quantity at this point
Default how long to clear codes?
just wondering how many drive cycles it takes to clear a code after repairing the issue ? repaired a code p0442 . i have a 98 jimmy . thanks .
Old Mar 20, 2012 | 09:44 PM
Each DTC has it's own parameters for clearing, (they are not all the same).
Clearing P0442: The PCM turns off the SES after 3 consecutive drive trips, (not drive cycles) when the test has run and passed. If the SES light is still on, the problem is not fixed.
A history DTC P0442 will clear if no fault conditions have been detected for 40 warm up cycles, (coolant temp has risen at least 40F from the start up coolant temperature and the engine coolant is more than 158F during the same ignition cycle).
The only way to manually clear all memory files is with a scan tool capable of accessing and clearing the history file, (not all scan tools can do this). Simply disconnecting the battery will not clear the history file.
Old Mar 21, 2012 | 12:34 PM
thank you . that is the exact info i was looking for ..
bigjoewebb
Jan 27, 2009 09:36 AM
92txblazer
Detailing
Aug 13, 2008 11:02 PM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
