How long do these last in comparison
Old Oct 26, 2008 | 10:23 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default How long do these last in comparison
Ive been looking around at cooling fan clutches and electric cooling fans. Both are about the same price and I know an electric fan will save a tiny amount over a properly working fan clutch. Right now my clutch is basically stuck on its been like that as long as I have had it. About how long does a fan clutch last in comparison with the electric cooling fans?
Old Oct 26, 2008 | 10:52 AM
Asimm's Avatar
Asimm is an unknown quantity at this point
Default RE: How long do these last in comparison
why dont you just get a fan without the clutch?
Old Oct 26, 2008 | 04:07 PM
jsmz's Avatar
Banned for childishly attempting to delete all his posts
jsmz is an unknown quantity at this point
ORIGINAL: Asimm
Probably the same reason it was a must to replace the fan clutch in my mothers 1st gen. It took FOREVER to get up to operating temp in the winter.
Old Oct 26, 2008 | 07:38 PM
portcqb's Avatar
Yah that and its a waste of gas to have it spinning when its cold and when on the highway.
Old Oct 28, 2008 | 11:10 AM
portcqb's Avatar
anyone else?
Old Oct 28, 2008 | 12:00 PM
I do not share in your statement that an electric fan will save over a properly functioning fan clutch. Unless you go through the trouble of installing cut off thermostats (plural if you are running a two speed fan), then your electric fan will be running all of the time, drawing crank horsepower the whole while. The stock thermo-viscous fan clutch only draws power when the heat being pulled through the radiator is hot enough to engage the clutch.
As far as which will last longer... Probably a crap shoot. You could get a bad thermo-viscous clutch just as easily as getting a bad electric fan. I would consider the stock arrangement as more robust due to its simplicity. But that is, of course, just my opinion.
apo02
Dec 13, 2012 03:58 AM
SlipAngle
Oct 31, 2010 11:39 AM
Jimbotopotomous
Tires and Wheels
Aug 27, 2010 10:58 PM
celchlepp
May 21, 2010 08:06 PM
volfan4
Nov 28, 2009 08:04 PM
