How much will it cost me?
Old 11-28-2006, 05:35 PM
kornphlake is an unknown quantity at this point
Default RE: How much will it cost me?
I just did my ball joints over Thanksgiving, total it took about 5 hours and cost about $80 for the 4 ball joints from Kragen, the quality may be questionable but they have a good warranty and around here they're the only parts store that has employees who know how to treat customers.
I could have done it a lot quicker if I had been a little more reckless with the sledge hammer pounding out the passenger side lower joint. After fussing for about 30 minutes I ended up heating the lower control arm with a torch to let it expand then whacked the ball joint a few times with the sledge hammer and it came right out. The driver's side came out with some extra angry pounding with a 3lb sledge and no torch, put a bottle jack as close to the ball joint as you can and whack it from above, if you've got a buddy that can hold the spindle with a pair of pliers that will help. Watch out for the wheel wells when you're swinging the hammer, I dinged mine a little bit, thankfully it was on the backswing so it doesn't show. My dad has an air chisel he let me use without one I'd add a couple hours, with a better air compressor and a chisel that didn't need to be re-ground after each rivet I'd subtract 15-20 minutes.
Since I ended up needing a pair of wheel bearings too, I'm glad I did the work myself, I ended up spending about $500 for the ball joints and bearings, I'm sure if I'd gone to a shop I'd have easily spent $800.
jjsmith1228
10-26-2010 11:17 PM
88s10Blazer
12-29-2009 10:41 AM
CraigSnedeker
08-16-2009 12:40 AM
xNOOKx
04-24-2009 02:06 AM
wienerdog
10-15-2008 08:56 PM
Quick Reply: How much will it cost me?
