Hub Bearing replacement question
Old May 13, 2019 | 03:14 PM
RedBlezer's Avatar
RedBlezer is on a distinguished road
Default Hub Bearing replacement question
Have had a rotating rubbing noise that varies with speed thats been getting worse for a while, sounded like it was coming from passenger side. I replaced the hub bearing with a timken unit and found when I installed it there was a lot of resistance on the 3 bolts. Is this typical? Felt like I was really forcing it.
Still have a rotating rub but is not quieter and sounds like the drivers side (alignment guys said both bearings were bad but passenger was worse).
Going to change the drivers side before this weekend hopefully. Main concern is the resistance when reinstalling the hub. Felt like the cv shaft was too long and I was forcing the hub past the splines and onto the shoulder.
Old May 13, 2019 | 05:40 PM
odat's Avatar
If you had every thing clean maybe a hair bit of wear on splines causing a slight unseen ridge creating a drag ???? Been there seen that ....
Old May 13, 2019 | 05:45 PM
RedBlezer's Avatar
Old hub slid off due to all the anti seize on the spline. Didn’t clean it up at all, just reinstalled. Drivers side cv is toast and will replace with the hub this week.
Old May 19, 2019 | 10:14 PM
RedBlezer's Avatar
Both hubs and bad cv are replaced, no more noise while driving
Drivers hub was a lot easier, but at the end was still very difficult to seat the hub to the knuckle at the last 1/10 of thread. Kept thinking I was over tightening, but I could still shake the brake dust shield. Oh well took it wheeling and it went fine.
Old May 19, 2019 | 10:38 PM
odat's Avatar
Kool hope it holds up for you
Raman04
Jun 5, 2017 02:42 PM
blazintexas
May 27, 2012 03:57 PM
PaulO2288
Aug 6, 2010 12:18 PM
green75
Oct 24, 2009 11:41 AM
Booztd
Feb 22, 2007 11:08 AM
