HUGE FUEL PROBLEM. please help me.
Old Jun 27, 2010 | 08:42 PM
laidblazer's Avatar
laidblazer is on a distinguished road
Default HUGE FUEL PROBLEM. please help me.
i need help guys, i have a 96 s10 blazer 2wd. It has the 4.3 in it. i was getting around 320 miles to a tank then one night all of a sudden i started getting 115! I had the codes pulled and it said all the O2 sensors were bad and it had a random miss fire. i changed all the oxygen sensors, the MAP sensor, the fuel pressure regulator, and cleaned the injectors, throttle body, and MAF sensor. Now i know that my cat converter is bad, exhaust man told me that. i have a new one to go on this week. After all that i've already done it is no better. when we pulled the injectors out the tubes going to them we a lil melted. we cleaned the whole thing and the top of the intake with carb cleaner. I have no clue what else to do. If anyone has any ideas please help.
Old Jun 27, 2010 | 09:15 PM
1998MSO's Avatar
1998MSO is on a distinguished road
A misfire could be caused by an ignition issue such as worn out spark plugs/wires etc.... Have you checked that? That could also be the cause of a catalytic converter failure.
Old Jun 27, 2010 | 09:42 PM
4x4blazerguy's Avatar
If you cat is plugged that explains the fuel mileage. I agree on the miss fire plugs or wires. I had a year old set of NAPA wires burn the end off the #1 plug. I fixed that & my miss fire ended. I think the best wires for the money are AutoZone.
Old Jun 27, 2010 | 11:14 PM
laidblazer's Avatar
thanks guys. What bout the EGR valve? someone said to check that. i know nothing about motors. lol i
Old Jun 28, 2010 | 06:20 AM
95Jimmy's Avatar
95Jimmy is on a distinguished road
The scanner will give you a code if the EGR isn't working properly.
Old Jun 28, 2010 | 12:06 PM
CodyJames's Avatar
CodyJames is on a distinguished road
I am experiencing something very similar to this. Scanner gave me a P0420 code, bad catalytic converter, or 02/H02 sensors, so I will try replacing sensors first.
I'm also experiencing the random misfiring, mainly when I'm idling at a stop light or sign. There is a faint "zapping" sound when the misfire occurs, which leads me to believe it's something to do with plugs, but I changed my plugs 2 months ago... I could also use some help.
Old Jun 28, 2010 | 10:15 PM
1998MSO's Avatar
Hey Cody,
Did you change the plug wires as well?
Old Jun 28, 2010 | 10:21 PM
BlazerLT2001's Avatar
BlazerLT2001 is on a distinguished road
My husband's s-10 had a similar issue, he changed his plug wire and it helped. Good luck to you!
Old Jun 29, 2010 | 07:13 AM
CodyJames's Avatar
@1998MSO & BlazerLT2001
I did not change my wires when I changed my plugs. I will give that a shot. Thank you both.
Old Jun 29, 2010 | 12:03 PM
CodyJames's Avatar
I've been doing a little more research today and read that a blown Fuel Pressure Regulator could cause all of the symptoms we are experiencing. Replacing that might be worth a shot too. I'm going to try it.
